New ABS sensor - still getting fault
Old Apr 24, 2016 | 10:13 PM
Extinct's Avatar
Originally Posted by synergyautp
Done it a couple times. Run along the frame rail together and through the firewall directly to the control unit. It's a piece of cake once you get going with it.
These cars are notorious for connector issues. There are two big connectors that are orange and grey near the expansion tank that are very problematic.
How do you splice in to the harness at the ECU? Do you cut and splice the wires going to the ECU? Scotchlock? Or pull the pins out the the connector and replace?
Old Apr 25, 2016 | 07:18 AM
synergyautp's Avatar
4wd High
Cut the wires near the connector, far enough away from it to solder the new wires to.
Old Apr 25, 2016 | 03:50 PM
Extinct's Avatar
I was afraid you were going to say that, I really hate the idea of cutting the oem wire harness...
Old Apr 30, 2016 | 09:02 PM
Extinct's Avatar
Well, I rewired the left rear from the sensor all the to just after the connection under the hood (I bought too short a piece of wire at Lowes - shielded 2 conductor). Same code. I guess the next step is by a longer piece of wire and go all the way to the ECU, or try the later model ECU with the more fault tolerant algorithm.
But... I am out of time fooling with this truck - accepted a job in Lynchburg VA and won't have time to fool with this during the relocation - look for the truck sale post in the classifieds section.
no7rosman
Nov 2, 2013 10:51 AM
06Range
May 8, 2013 09:01 PM
