New foam on the a/c diverters
Old Jul 9, 2017 | 12:28 PM
Luckyjayb's Avatar
Default New foam on the a/c diverters
has anybody got a good write up on the a/c door foam replacement? Noticed the foam has been deteriorated and need replacement to help divert everything properly.
Thanks in advance
Old Jul 9, 2017 | 01:54 PM
acg's Avatar
acg
Do you mean the long foam strip just above the front plastic cowl where the wipers are located?
You can find similar foam material at Home Depot and cut it to size to fit. Perhaps something like this:
http://www.homedepot.com/p/Frost-Kin...1524/202318549
Old Jul 9, 2017 | 02:18 PM
Luckyjayb's Avatar
No the ones on all the flaps inside the blower unit. They have all deteriorated and I want to reseal them up
Old Jul 9, 2017 | 05:48 PM
OffroadFrance's Avatar
Post how you get on with these Luckyjayb as mine need doing also and I fear it's a biggish and messy job to do. IMO you'll need some heatproof foam and glue, probably impact adhesive to glue the new foam pads into place.
Old Jul 9, 2017 | 06:32 PM
Luckyjayb's Avatar
2 are accessible if you remove the windscreen cowl, 2 are accessible if you remove the dash center and I'll have to look at the schematic for the rest. I was thinking headliner spray adhesive and push em good onto them since it is high temp glue
Old Jul 10, 2017 | 05:13 PM
Good one Luckyjayb, I didn't think of headliner adhesive
Old Jul 10, 2017 | 08:50 PM
Luckyjayb's Avatar
That's what I used when I rebuilt and old 1978 ford f100 to hold the foam in place. I also used the flat foam out of a pelican case
Old Jul 11, 2017 | 12:00 PM
emncfi's Avatar
I used a thick window sealant foam for house Windows from lowes or Home Depot. It came in a roll and I just cut down the pieces I needed, had to do it for the roof vents for the rear AC. Seems to have worked
bigugly82
Mar 14, 2018 05:09 PM
archaeology_student
Aug 13, 2013 06:53 AM
rtz62
LR2
Apr 28, 2012 10:01 AM
mowthat
Feb 14, 2007 10:03 PM
mikemeyer0
Jun 16, 2005 04:00 PM
