new hub?
Old Feb 27, 2008 | 03:45 AM
redlodge's Avatar
Default new hub?
I have a discovery, automatic, diesel 2001. the following warning lights came on: hill descent, abs and traction control.
Took to my 4x4 garage and they replaced a sensor. Ok for a day then all lights on again. Garage think it is now a replacement hub needed which is expensive. Has anyone else had this happen? Should the garage have been able to tell it was hub from start instead of replacing a sensor?
thanks
Old Feb 27, 2008 | 08:53 AM
Default RE: new hub?
How many miles on your truck and has it been used hard off the road?
You can have 2 things causing that problem, a bad wire harness, which is known to happen, or a tired hub that has just enough movement to mess up the speed densors signal.
Old Feb 29, 2008 | 10:29 AM
NJDisco's Avatar
4th Gear
I'm certainly not an expert but I had the same experience with my vehicle. After the 3 lights occurred, I needed a new hub and harness. Bought the replacement hub on my own and had local rover shop install it. It got rid of the 3 amigo warning lights for about a month, after which I needed a new sensor. Looks like we had the same experience, except reversed. I'm hoping the lights won't come on again because I will then need a different sensor replaced. It all feels like trial and error to me, but I am by no means an expert. Good luck with yours!
Racer X
Oct 10, 2016 09:32 AM
tbesselman
Feb 22, 2010 02:41 PM
USMC_Denver
Apr 21, 2009 05:58 PM
98xc800
Sep 30, 2008 04:51 PM
ajh
Nov 21, 2007 12:33 AM
