New to me D2 SD
Old Jan 29, 2015 | 12:28 PM
  #21
dusty1's Avatar
wait......you shouldn't need to remove the panel to install a ladder. everyone that I have seen just slides over the top of the door and bolt away.
Old Jan 29, 2015 | 12:41 PM
  #22
slammin_LWB's Avatar
I wanted to run bolts thru at the bottom instead of rivnuts.
Old Jan 29, 2015 | 12:55 PM
  #23
dusty1's Avatar
gotcha
Old Feb 3, 2015 | 09:44 AM
  #24
Today this will happen.
In other news, had my first run in with the SES on this truck. Romped on the truck leaving my parents. TC activated, and I ended up with a miss. SES came on, blinked a few times. I cut the truck off, restarted....misfire gone. SES still one. GF drove the truck yesterday, SES off.
Also discovered a nice leak, running down the trans cooler line and dripping on the left cat. Maybe ATF, I think it's oil. Going to investigate while I swap out the front prop-shaft.
Also, my old key was missing the lock button. Got a new housing with the truck, swapped the board into the new housing and noticed the lock microswitch was missing the button portion. So I found replacements on ebay for like $8 shipped, or I can get bags of 100 for less, but I won't ever need these again, so yeah.
Old Feb 3, 2015 | 10:02 AM
  #25
Also, I'm going to add a trans dipstick.
Crawling under there to check/top up trans fluid is ridiculous.
Old Feb 3, 2015 | 10:48 AM
  #26
dusty1's Avatar
did you find a d1 pan, for the tranny? or.........?
Old Feb 3, 2015 | 11:18 AM
  #27
Trans kits are the same D1 to D2, so I could do that. Probably easiest way.
Old Feb 3, 2015 | 11:46 AM
  #28
dusty1's Avatar
yes. that has always been my plan for a dipstick. but I never can.seem to find a salvage d1 with a tranny pan.
Old Feb 3, 2015 | 02:46 PM
  #29
While I'm here, what's the deal with retrofitting options from other trucks onto mine? Mines pretty poverty spec, no sunroof, front fog lamps, etc....
Mainly I want heated seats and heated windscreen.
I do this with BMWs all the time. It's usually a plug n play deal. Cruise ctrl, heated/power seats, memory functions.....etc....
Heated seats, I assume I'd need the buttons, console, any leather seat.....worst case the wiring harness....but if these are like BMWs, they're all pre-wired for the top of the line. Doesn't make sense to make 50 different harnesses.....
Windscreen, I have the plugs under the cowl, so I guess I'd just need the windscreen and button?
Maybe if I get uber ambitious rear AC is a thing too....but IDK if I'm going to go that far. 3rd row seats I will have to get my hands on though.
Old Feb 3, 2015 | 03:32 PM
  #30
dusty1's Avatar
rear ac sounds like a very ambitious goal, but doable. seats and stuff is going to be easy enough. same deal, wires are there. just need the goods and switches
