New member and have a question
ORIGINAL: mikemeyer0
i would still say drive shaft area, thats what i check on mine and after replacing my u-joints it went away.
be sure you do it ASAP, as the rattling can tear up some of the pieces of the U-joint and make it quite difficult to remove (trust me on that one) you'll need to get one wheel off the ground and pop your tranny or transfer case in neuteral to get to all the bolts on the shafts, be sure to chalk the tires. try not to seperate your drive shaft once you get it off. mark it just in case. this is to keep everything balanced. also make a note of where the grease nipple (XD) is, once again, balance. dont forget to grease everything back up when your done.
anywho, i hear hitting your shafts and joints with a grease gun every now and then will help prevent this problem from happening in the first place.
Thanks for you response. does anyone have any pictures showing how to take it off? And are there two u-joints? One in the front and one in the back of the driveshaft?
jimmyvietvu
Mar 31, 2014 09:22 PM
CCRovers
Jan 30, 2013 11:01 AM
strictlyb
Jan 28, 2010 11:10 PM
95GreenDisco
Dec 4, 2008 09:32 PM
johnnyd
Feb 23, 2008 08:09 PM
