New O2 Sensors, now SES Light
Old Feb 24, 2016 | 02:41 PM
Oasisplayer311's Avatar
Default New O2 Sensors, now SES Light
This is on my 2003 Disco II with 85k on it. My my engine has been running rough ever since I did the head gasket job a few months ago (I also changed the timing chain, cogs, oil pump, Thermostat to the cooler running one, and water pump). New coil packs with magnacore 8.5 (Red Color) and Bosch x4 Plugs. No check engine light for months, but engine shake while idling.
So I decided to replace my front/upstream O2 sensors with Bosch O2's (Part# 15175). Cleaned connections, started her up and the engine shake is WAY worse.
I threw 3 codes after I switched the O2's which include
P0150
P0126
P1590
Ordered the replacement plugs for the downstream O2's which I chose to go with the NTK's (OEM O2s) to see if that helps. Any help would be appreciated!
Old Feb 24, 2016 | 10:30 PM
LR03NJ's Avatar
P0150
P0126
P1590
Is that P1590 or P1509 (Idle Speed Control Short Circuit Fault)?
http://www.wikihow.com/Check-an-Idle-Air-Control-Valve
Old Feb 24, 2016 | 10:44 PM
4 Ways to Check an Idle Air Control Valve - wikiHow
Its a P1590, which makes sense because I replaced my upper and lower ball joints a months back and ever since my Traction Control will kick in when I hit 1200 RPMs, so I disconnected the front wheel speed sensors and haven't had the problem since. Other than a christmas tree of lights on the dash lol (ABS, E-Brake, ABS, Hill Decent)
Old Feb 24, 2016 | 11:05 PM
number9's Avatar
P0126 - Engine thermostat defective - Difference in radiator and engine coolant temperatures too small
P0150 - O2 sensor circuit malfunction (bank 2, sensor 1) - Front sensor RH bank stoichiometric ratio outside operating band
P1590 - ABS rough road signal circuit malfunction - Hardware is OK, but SLABS ECU is sending an error signal
One O2 related.
Old Feb 24, 2016 | 11:42 PM
Originally Posted by number9
One O2 related.
Does the P0150 code represent the Upstream O2's? Which side?
Old Feb 24, 2016 | 11:45 PM
I also unplugged the battery today for almost an hour to clear the codes. Checked my coolant, level was right at the (Cold Level) mark, so decided to top it off to the brim. Reconnected everything after an hour and SES light is off. Drove it around for a bit and nothing. Turned it off and back on, and still no SES light.... Fingers crossed
Old Feb 25, 2016 | 12:42 AM
number9's Avatar
I'd assume so, that's "ed from manual but fortunately have yet to need the info on mine.
Old Feb 26, 2016 | 12:35 AM
Is "RH" Driver or Passenger? Plus, since unplugging the battery for an hour, I've yet to throw a SES light, hoping for the best! The downstream O2 sensors come in on Monday
Old Feb 26, 2016 | 05:05 AM
number9's Avatar
References
References to the LH or RH side given in this Manual
are made when viewing the vehicle from the rear.
steveo2000
Oct 30, 2024 08:31 AM
pjvarc
Aug 5, 2011 04:23 PM
Disco_Fever
Apr 26, 2011 11:59 AM
greenwade
Mar 18, 2010 06:50 PM
audioclay
Oct 29, 2009 08:49 PM
