New please help!
Old Jul 31, 2013 | 07:32 PM
fcox062411's Avatar
Default New please help!
I am working on an 03 Landrover discovery with a 4.6 w/secondary air. The engine now I believe has a slipped sleeve or more. Either way the engine makes an awful ticking noise that has only gotten louder with time. I tried the thicker oil 20/50, which only helped slightly for a short period. Rather than the expensive hassle of getting a head job, i have purchased a used engine with thirty thousand less miles. I am trusting the engine is good only because it comes with a warranty. My problem is I have never worked on one of these engines before, I am confident however; in my ability to do so. What I dont have is access to all data and in dire need of installation steps and procedures along with torque specs and bolt sequences. I want to do this right the first time. Any help would be greatly appreciated.
Old Jul 31, 2013 | 07:47 PM
ralphobell's Avatar
1st go here: https://landroverforums.com/forum/di...st-read-26356/
Then Go here: https://landroverforums.com/forum/di...t-reads-26352/
Then go here: https://landroverforums.com/forum/ge...ing-lr3-57978/
That should get you started.
Old Jul 31, 2013 | 07:52 PM
NickAdams's Avatar
Ralph helped you out good. No need to elaborate. Follow his instructions for best results.
Old Jul 31, 2013 | 09:11 PM
First of all you should have checked with us or some one prior to buying another engine.
You might want to PM me your number so we can talk and I can walk you thru exactly what you need to do or check before you throw an engine at your truck.
Old Aug 1, 2013 | 06:39 AM
drowssap's Avatar
it has 30k less miles than what you have? how many are on it? 30k less could mean it only has 170k instead or 200k.
Old Aug 1, 2013 | 09:12 AM
And we also have posts about pinning the liner and stopping ticking.... this is a resourceful band of devoted followers of the green oval.
But one question - does this ticking start when engine is first cranked (valve train), or must it warm up for it to begin (liner)? Have you located the noise with a listening stick (yard stick held to ear and touched to valve covers, etc.)?
Old Aug 1, 2013 | 05:10 PM
jfall's Avatar
Well if you can not hear that replacement engine running before you bought it, then you may go thru a lot of work and still have an engine with problems.
I hope not but..
Old Aug 1, 2013 | 05:24 PM
FlyingZebra34's Avatar
If your problem is ticking on warm up... what kind of implications does that have? Negative effects?
Old Aug 1, 2013 | 08:36 PM
If ticking starts cold and continues, it is usually not the sleeve. Can certainly be valve train. THe thought is that the sleeve begins to slip when engine gets to a certain temperature, and that it can even stop when rpm goes up, because slipping liner can't keep up with piston travel. So noise goes away at rpm, and comes back at low speed.
But it may have done all that with a previous sowner. And now is ticking all the time.
You would think with the cheap gas we burn that gunk would build up and hold the liner in place....
Paul Aspen
Nov 4, 2013 02:10 PM
tarpon66
Jul 27, 2011 12:38 PM
sawadeh
Jul 2, 2011 08:10 PM
MuddMouth
Sep 30, 2010 10:30 PM
