New Shocks going in, what else should I do?
Old Apr 16, 2021 | 10:50 AM
swissarmychainsaw's Avatar
Default New Shocks going in, what else should I do?
Hey Rovers,
I just bought some Bad-*** Bilstein shocks from my 2000 LR D2, and I'm wondering what else I should do while I have the thing dangling in the air.
I plan on wheeling this thing (more!)
200K Miles
I plan on doing rear Air Bags.
Keeping the Shock Towers stock (what's the advantage of Terra Firma here?)
Replacing the starter (cranks REALLY slowy, intermittently)
What obvious stuff should I do here?
Thanks!
Old Apr 16, 2021 | 11:01 AM
zski128's Avatar
If your coil springs are shot/old they will drastically reduce the life of your new shocks. If you are in the rust belt the stock shock towers are thin and can rust and weaken. Aftermarket towers are usually beefier. The coating TF uses is awful, I would clear coat/ paint anything you get from them.
Old Apr 16, 2021 | 11:27 AM
redwhitekat's Avatar
i had the terrafirma towers, worth every bit, my oem fell apart when i took them out,
Old Apr 17, 2021 | 04:31 PM
Discorama's Avatar
I put air bags into the rear springs. It allows to adjust the height when fully loaded, makes the suspension harder and the truck more stable on winding roads.
Old Apr 18, 2021 | 07:32 PM
That's a great idea! Can you give the tech specs on the airbags you used? Brand and model?
My is a stock airbag model, and I'm replacing the Bags with Dunlop replacements (mine leak overnight) I like the ride and the fact that they self level!
Old Apr 18, 2021 | 09:03 PM
Discorama's Avatar
Do the coil spring conversion a get a kit from Firestone (Coil-Rite: 4121) for hundred bucks. It gives you the durability of coil springs but adds additional weight capacity and driving stability as needed.
Old Apr 19, 2021 | 10:38 AM
whowa004's Avatar
And this hooks up to stock air compressor or is this something you set based on your load/driving conditions? Simple question I know but I'm new to the air helper world.
Old Apr 20, 2021 | 02:18 AM
Discorama's Avatar
I fill them up with air at home like tires before I leave for a trip. Lasts weeks without any noticeable pressure drop. I have an onboard compressor but used it for tires only so far.
driller82
Dec 8, 2021 01:17 PM
partsguru
Jan 18, 2016 07:39 PM
thehun
Sep 14, 2013 07:52 AM
EstorilM
Feb 24, 2011 01:52 AM
Fonzie
Nov 1, 2007 09:07 AM
