New Upstream O2 sensor .445 Voltage
Old Jun 17, 2020 | 03:14 PM
DiscoBuckeye's Avatar
Default New Upstream O2 sensor .445 Voltage
Anyone ever install a new O2 Sensor and have it read perfect voltage but other than that, it's dead?
Old Jun 17, 2020 | 05:49 PM
XRAD's Avatar
in closed loop, should oscillate voltage...
Old Jun 17, 2020 | 05:54 PM
Yes understand when it's working right
Old Jun 17, 2020 | 07:00 PM
Extinct's Avatar
Very common, you can confirm with a scanner that graphs voltage. Cheap elm327 from Amazon and the free torque app will do it.
Old Jun 18, 2020 | 09:39 AM
That is how I identified that I was getting the voltage. Bummer if its a defective unit right out of the box
Old Jun 18, 2020 | 09:52 AM
Jason Feuerstein's Avatar
That's fairly common with how delicate they are. Delivery guy drops them on your front step and they could go.
Old Jun 18, 2020 | 01:41 PM
Extinct's Avatar
If you have a scanner that will chart, look at it from cold start, they shoudl start about 1v when cold and then after 2-3 minutes start cycling. If it does not do that - bad sensor. Easiest way to test is swap left to right assuming you have one good one.
Old Jun 19, 2020 | 11:48 AM
matt3502's Avatar
Had that problem with a number of Bosch sensors purchased via AMZN. After 3rd try went with Walkers from AB and have never had an issue. Walker price is very good.
Old Jun 19, 2020 | 05:23 PM
Extinct's Avatar
RockAuto has Walkers on sale right now - $23?
Old Jun 19, 2020 | 05:40 PM
That was what I got from RA but it wasn't an Walker
Carlos Man
Sep 15, 2021 02:38 PM
ammonation
Aug 2, 2021 11:15 PM
jsaenz
Apr 24, 2020 04:31 PM
cobbcj7
Sep 20, 2016 04:04 PM
NiteTrain
Nov 24, 2010 04:39 PM
