Newbe needs HELP! ABS Problem.
Old May 8, 2006 | 12:15 PM
MJSVG's Avatar
4wd High
Default Newbe needs HELP! ABS Problem.
Newbe here! I have another little problem with me rig. The ABS kicks on for no reason, usually when coming to a stop. I'll be going 10MPH on drive clean pavement, and ABS starts and takes me three times further to stop. I've already tried replacing the ABS ECU. Didn't help. Any ideas?
Old May 9, 2006 | 02:33 PM
Default RE: Newbe needs HELP! ABS Problem.
Michael,
You really need to go have the ABS scanned for codes at the dealer, see what they find, write it down by code # and get back to us to see if we might be able to help you thru this.
Mike
Old May 11, 2006 | 01:57 PM
hoberock's Avatar
My ABS on my '97 was acting up, so I cleaned the sensors and the parts on the rotor side, then readjusted the senor spacing. Seems to have done the trick so far. You might give this a try. Also you may check you vehicle speed sensor.
Old May 11, 2006 | 03:55 PM
ORIGINAL: hoberock
What you did with your truck is usually all that is needed to correct most Rover ABS problems.
Mike
Old May 12, 2006 | 01:19 AM
Bait's Avatar
ORIGINAL: MJSVG
How did you do that?
Old May 13, 2006 | 12:50 AM
MJSVG's Avatar
4wd High
I will try cleaning the sensors, and see if that helps. Will changing tire size effect the speed sensor to the point of effecting the ABS? Thanks!
Old May 13, 2006 | 09:55 AM
Landzu's Avatar
Changing the tire size will not effect the speed sensor or the ABS.
I have 245-75-16 and no problems.
Old May 13, 2006 | 01:00 PM
ORIGINAL: Disco Mike
Michael,
Mike
I still stand by my first message, if you had lots of ABS experience I would suggest you get dirty, but without knowing what to look for, go get it checked, get the codes, have them cleared, drive it and see if they come back, if they do get back to us first with the old codes.
Mike
Old May 15, 2006 | 01:32 AM
MJSVG's Avatar
4wd High
I have an OBDII checker... Will this also check the ABS codes? I'm poor and a novice mechanic... Probably a bad combo for owning a Rover!
Old May 15, 2006 | 01:32 PM
ORIGINAL: MJSVG
For some reason you are in the norm. As for you question, no a regular scanner won't access the ABS codes, need a test book or some other high end$$$ ABS scanner.
How are your brakes working now, with the lights on? Can you feel the ABS engage when braking on a slippery surface? If you can feel them working, you most likely had your truck throw a code indicating that there was a slight problem and it is OK. The lights just won't go off by them selves.
Have your brakes been squeaking, getting hot, dusty, new after market pads or is your brake fluid old and brown? Any of these will cause a possible code.
Mike
martin
Oct 6, 2011 01:09 PM
freddy
Aug 30, 2011 08:02 PM
catman634
May 3, 2011 09:47 AM
ecf716
Apr 21, 2008 03:59 AM
4ruf
Apr 19, 2008 09:55 PM
