Compression test good...
New wires
New plugs
New coils
Idles goes into closed loop, then randomly goes into "Fuel System Error" at the same time as P0301... when flashing SEL goes off vehicle back into closed loop. P0301 at the same time as Fuel System 1 Status (8) Error. OBD2
Given it comes and goes, I would suspect the purge valve as well. Vapors will cause engine to run a little rich - normally the ECU compensates by dropping injector pulse width but if it is leaking - maybe? You can see from the 02's it actually does go rich at that point.
