no a/c passenger side
Old May 10, 2012 | 07:35 AM
newworld's Avatar
Default no a/c passenger side
i have no a/c on passenger side. no matter what setting temp it blows just air no a/c. the drivers side is better and cooler. i understand that it might be servo motor issue for the blender flap. there is NO writeup on how to tackle this issue.
if anyone has even tried to tackle this problem. please write in.
i did a psi check on low and high side and seems to be be charged with freon.
i even tried calling parts supplier to get a servo motor and they said didnt have it in stock.
Old May 10, 2012 | 10:21 AM
Might want to look in the R A V E for your truck
Old May 11, 2012 | 07:40 AM
newworld's Avatar
Default no ac passenger side
does anyone have this problem and can offer their experience?
thanks.....
Old May 11, 2012 | 08:08 AM
Page 79 of 152 in the circuits diagrams (air conditioning, not heating and ventilation) shows the motors and connector wiring, direct to HVAC ECU, no extra fuses. Five wire connector, two for motor, three for sensors that relay position information. Can remove connectors and meter and compare. C0539 and C0415 are the numbers, pictures of location are in connector section of electrical library (page 471 of 705). Also see page 1177 of 1529 in the shop manual, it mentions that you have to drop the main HVAC blower to access the passenger side servo motor. That blower is kinda pricey, so careful; also good time to clean out leaves and such.
cosmiccharlie
Aug 12, 2020 01:42 PM
post42
Sep 10, 2013 03:33 PM
Spencerfitch
May 3, 2010 02:56 PM
Young
Jul 22, 2009 07:51 PM
