No Drive!!!
Old May 2, 2013 | 10:03 AM
  #21
texgant's Avatar
Thanks for all the info I found a guy that will sell the differential and a 99 transfer case for 350.00 shipped to me.
Old May 2, 2013 | 10:11 AM
  #22
ZGPhoto's Avatar
Nice! That's a good deal.
Old May 2, 2013 | 10:27 AM
  #23
kfx4001442's Avatar
How do we know its the diff and not an axle? Is it apart yet?
Old May 2, 2013 | 10:38 AM
  #24
ZGPhoto's Avatar
Nobody knows whether it's the diff or axle yet.
Old May 2, 2013 | 10:41 AM
  #25
texgant's Avatar
I would say because of the loud clunking sound that it has been doing for the last couple weeks. But it would never do it while I was looking for it and it has had what I thought to be an extensive amount of travel in the ring gear to pinion ever since I got it.
Old May 2, 2013 | 11:03 AM
  #26
texgant's Avatar
What did you have to change on yours when you installed the transfer case?
Old May 2, 2013 | 11:04 AM
  #27
ZGPhoto's Avatar
Ended up replacing the transmission output shaft as it was not aligned properly and it was scored. Other than that it was just the t-case and t-case linkage.
Old May 2, 2013 | 11:09 AM
  #28
Originally Posted by texgant
Manufacturing date is 11 of 01
Even that is most likely too old of a production date, Rover ran out of the old style t/cases just after the middle of the production date, maybe around April or May.
Old May 2, 2013 | 11:12 AM
  #29
Where did you get your transfer case did you ho New or used
It is easier and cheaper to replace the nose assembly, linkage and Hi/Lo shift plate on your current t/case then buy and install a used one that may already have mechanical issues, all for around $250 in parts and your labor.
Old May 2, 2013 | 11:16 AM
  #30
Find out how many miles on those 99 parts, you don't want to buy a diff that is already warn out. Beside, you first need to find out if the spider gears or the cc joints failed before you do anything.
DiscoJon
Jul 14, 2019 01:51 PM
TripleThreat
Apr 12, 2011 08:58 AM
Randy P
Sep 27, 2007 08:27 AM
05LandRover
Off Topic
Jan 16, 2006 09:49 PM
Big boy
Mar 25, 2005 10:08 PM
