No Heat at Idle
Old Feb 2, 2013 | 11:38 PM
Aaron Sandland's Avatar
Default No Heat at Idle
1999 Disco 2 129k miles
It's been cold very cold. Not getting heat at idle but I am getting proper temperature in engine.
Some water swishing noises heard lately, should I do a flush?
Old Feb 3, 2013 | 12:22 AM
bballjames's Avatar
You probably have air in the system. It needs to be bled properly. Your heater core may also be partially clogged and need to be flushed.
Old Feb 3, 2013 | 06:51 AM
coors's Avatar
Search for "How to Properly Bled Cooling System" and follow the directions. Sounds like you have air in the system. ave you done any maintenance on the cooling system recently?
From cold (referring to engine temperature).
Open bled screw, remove coolant reservoir from housing, remove coolant reservoir cap, hold it above the engine and allow system to 'burp' any excess air. Sometimes, it helps to elevate the front wheels.
Old Feb 3, 2013 | 09:40 AM
And, after bleeding the system, check the coolant every morning before a cold start, it it keeps dropping and the gurgles come back then someone needs to do a coolant pressure test to find your coolant leak and fix it.
Old Feb 3, 2013 | 09:52 AM
Thanks all. Will do this today and give an update
Old Feb 3, 2013 | 09:57 AM
Do not drive it again till it is bled and as mentioned before check the coolant level, cold, every morning so you can tell if there is a leak.
jmason
Nov 17, 2013 06:39 AM
Disco2Fever
Feb 9, 2010 07:03 AM
JStephen
Feb 2, 2010 06:59 PM
VikingDiesel
Feb 23, 2009 09:01 PM
eurosport1
Nov 25, 2008 03:02 PM
