No heat at low rpm
Old Mar 28, 2016 | 09:54 AM
LR03NJ's Avatar
That could be the reason why. I know that the install goes how the hoses are angled. I also wonder if that can installed the other way almost the the inline mod and pug the other side. Would that be possible?
Old Mar 29, 2016 | 01:58 AM
Susvman's Avatar
Originally Posted by Bom2oo2
What do you mean by top 2 hoses switched on T-stat,? You can only instal it one way, the one that comes out of side of T-stat in an angle is return hose to supply the cold coolant from radiator back to engine, the one on top of T-stat is to give hot coolant to T-stat to activate it & make wax hot to open T-stat, I hope you didn't instal It other way, if you have that will explain your problem.
I agree and it's installed just as you explained but the fact that the flow is weak through the heater core at idle is driving me crazy and it's not because of air in the system. I've bled the system and it's good. Didn't have a problem before the teardown so just suspect something is routed wrong or blocked. I'm thinking the issue may just be the Tstat itself.
Old Mar 29, 2016 | 08:53 AM
Bom2oo2's Avatar
With Land Rover closed loop setup , coolant circulates constantly trough heater core & around engine, it's a closed loop, & it goes trough radiator when
T-stat opens,, so even if T-stat doesn't work you should have circulation in engine & heater core all time & it will actually make coolant very hot & you will have lots of heat, insted of no heat,,,
So if you don't have heat from heater core it has nothing to do with T-stat itself,
It's either air in heater core or coolant doesn't circulate for some other reason,
But that will make engine overheat very quickly,
(Correction: T-stat can cause problem & not let heater get hot, but only way it can happen is if
T-stat is stuck in open position & coolant circulates trough radiator constantly)
jmason
Nov 17, 2013 06:39 AM
Papa K
Nov 2, 2012 03:31 PM
D90Driver
Jun 20, 2011 03:45 PM
muddybuddy
May 28, 2009 09:28 PM
jadedennill
Dec 10, 2008 07:11 PM
