No more resonator...
Old Dec 8, 2008 | 04:54 PM
hazletbassist89's Avatar
Default RE: No more resonator...
Ok on the NJ MVC web page it says the only things they check for are 1-Noise 2-Leaks and 3-Tampering-Catalytic Converter. Would removing the resonator cause it to fail any of these?
Old Dec 8, 2008 | 04:58 PM
Night Train's Avatar
Correct me if I'm wrong here...Thats a Mighty Nice looking set of Goodyear MT/R's, they still have the little anti swerve push rods on them . And Along with water backing up the exhaust if the engine is stalled in deep water I was always told that due to the cooling process if it is not removed from the water in short orderand you have any gasket or machining flaws - as the engine cools it will draw the water in past these flaws, or is that old school? I started off-roading in mid 70's, my first machine was an FJ 40 of which I've owned three.
Old Dec 8, 2008 | 04:59 PM
Switzer's Avatar
ORIGINAL: hazletbassist89
Sounds like you would be alright. The rules are specifically vague to allow inspectors to make their own judgments. Other than emissions, passenger safety is the next most important factor.
Cheers,
Pete
Old Dec 8, 2008 | 05:00 PM
To hell with it then, my car is due for inspection in February, so I'll put it off till I get that done with and then lop that sucker off when I get home Thanks for your help
Chrisinhouston
Nov 5, 2010 12:19 PM
humroot
Nov 24, 2008 09:11 PM
Camdisco24
Feb 11, 2008 04:42 AM
okdiscoguy
Apr 25, 2007 07:27 PM
tap121
Sights N Sounds
Apr 25, 2007 01:28 AM
