No Noise!
Old Oct 3, 2010 | 09:21 AM
SunCourtConstruction's Avatar
7th Gear
Default No Noise!
I recently replaced my burnt out radio and the new one will not play loud enough to here. so i went adventuring into my dash to find the stock amp on a salty 99 D-2. i have part of the floor consul torn apart too. I still cannot locate it or schematics on-line so i could locate it? can any one help?
Old Oct 3, 2010 | 09:35 AM
cwood's Avatar
Under the drivers seat maybe?
Old Oct 3, 2010 | 09:46 AM
mwindth's Avatar
SunCourt...here is the shop manual (RAVE): http://www.landroverresource.com/
Use the table of contents on the left hand side as it opens and look for the "In Car Entertainment" tab.
Old Oct 3, 2010 | 11:47 AM
7th Gear
Oh my thank you. you guys are great
Old Oct 4, 2010 | 08:54 AM
'BamaBoy's Avatar
Did you got the upgraded radio that requires the amp? Can just hear a little bit of the sound currently?
If so, I had the same exact problem. The amp is supposed to go under the driver's seat, however, there is no wiring running down there, so you'll have to wire an amp in yourself. Aftermarket is definately the way to go, the stock amps are outrageously priced, and require LandRover connectors and whatnot. The aftermarket amp took me less than a day to wire it all in, and it sounds ten times better than the original radio sounded.
http://www.sonicelectronix.com/item_...Power+760.html
I mounted this one right underneath my driver's seat where the stock DII amp should be. Fit's perfectly. I've ordered tons of stuff from SonicElectronix, and never have had a problem with them.
Old Oct 9, 2010 | 08:15 AM
7th Gear
Good call that's what it is, thanks
Old Oct 9, 2010 | 11:50 AM
7th Gear
Say do you know of a instruction site on installing amps. i am a little lost on this and cannot find what i am looking for on line
Old Oct 9, 2010 | 07:54 PM
7th Gear
got it. i am smiling for the first time in a month! thank you
Old Oct 9, 2010 | 07:59 PM
'BamaBoy's Avatar
Editing this because you JUST posted saying that you got it. LOL.
How does it sound? A little louder?
david4ducati
Mar 1, 2015 07:59 PM
30more
May 28, 2012 05:01 PM
adrianwood
Freelander
Jun 13, 2005 08:53 PM
