no power in gear
Old Jul 25, 2016 | 07:05 PM
Matt Humes's Avatar
4wd High
Default no power in gear
did headgasket replace on 02 disco2, starts and idles ok (little rough, broken stud and exhaust leak on driver side exhaust manifold). no power and dies when tryin to accelerate in gear..... engine light flashing
Old Jul 25, 2016 | 10:19 PM
disc oh no's Avatar
Do you know what the codes are? Recently, someone had some trouble like this after doing head gaskets. He later noticed that he didn't quite put one of the injector harness plugs together all the way. I think there's one on each bank.
Check all your electrical connections and vacuum lines. Make sure they're all tight and you didn't miss any.
Old Jul 28, 2016 | 05:32 PM
Matt Humes's Avatar
4wd High
Was in a hurry tonight but found that I had a few spark plug wires out of order I was able to correct them and I have no engine codes now but have not had time to drive it on the road to see if anything else pops up I was getting cylinder misfires but those are now cleared... I would be a horrible mechanic
Old Jul 28, 2016 | 06:20 PM
disc oh no's Avatar
That will certainly cause some problems!
bcolins
Jun 10, 2011 11:36 PM
discomedic4
Mar 30, 2010 01:19 PM
Lee1140
Dec 1, 2009 10:17 AM
rlp2011
Mar 13, 2008 04:21 PM
