No power to low beams - checked everything
Problem - Low beams do not work.
When I turn the indicator stalk to low beams the interior lights all turn on (backlight for dash/switches/etc). High beams & fog lights still work.
I’ve checked fuses, relays, and even took apart the indicator stalk to clean and confirm it works. Given that the interior lights turn on when I switch to low beams I don’t think it’s the stalk.
Am I missing something obvious or do I need to start following the wires looking for a bad ground?
I confirmed that the low beam wire at the headlight was not receiving power.
Afaik there are 2 relays to check and a couple fuses under the steering wheel.
![](https://cimg3.ibsrv.net/gimg/landroverforums.com-vbulletin/2000x1504/1d12f8cc_e519_472e_b0f6_b94723a18419_116a76e020997ab8e9bbd12c0d3fb99d0840249a.jpeg)
This is pre-cleaning. The copper is pretty worn down, but it Atleast sends a signal to turn on the interior night lights so the indicator is working.
Could be the connectors to the bulb. They can short out with old age. Mine did the same thing.
https://www.roverparts.com/electrical/headlights/6620R/
Received 1,189 Likes
on
The circuitry from the switch is pretty basic, one wire from switch goes to right headlight, passing through fuse 9 in fuse box and the other through fuse 10, these fuses are located in drivers compartment fuse box. If you turn on your headlights and dim them...fuses 9 & 10 should have 12 volts (both sides of fuse) and it travels from there to headlight socket. If you have no voltage at socket...then you have to check wiring harness or terminals within plug socket.
If you turn on headlights and you have no voltage at fuses 9 & 10...then it is most likely the switch. Having dash, dome, etc...have nothing to do with the circuit involving the headlights within the switch...so...just because those other circuits works...means basically nothing...other than we know they are working and getting voltage. Both low and high beams receive voltage to switch through fuseable link 10 in engine compartment fuse box...so...since high beams work...most likely fuseable link 10 is good.
Chris59 (02-10-2021)
The Deputy (02-11-2021)
