No Reverse Lights
Old Oct 4, 2018 | 01:06 PM
Fast951's Avatar
Default No Reverse Lights
Both reverse lights in the rear bumper have stopped working. I still get the proper gear selection readout on the cluster (PRND321) it's just the lights that don't work. Bulbs are tested good - bad XYZ switch?
Old Oct 4, 2018 | 06:24 PM
Twix's Avatar
Do you have power at the bumper fog lights? Could be many other things. I'd start checking for power at that fixture and work my way back, checking each connector
Old Oct 4, 2018 | 08:32 PM
mollusc's Avatar
I don't think XYZ switch because that would probably raise a whole lot of other problems as well.
Old Oct 4, 2018 | 10:01 PM
Red5's Avatar
One of mine would come and go. I found a bit of corrosion in the pins of each light assembly. I cleaned them best I could with some electrical spray cleaner and added a bit of bulb grease to each socket. Been fine for several years now. They get a lot of crap splashed up there even on the street.
04duxlr
Dec 6, 2015 08:37 PM
Alex_M
Nov 24, 2014 07:03 AM
CapeCod98Disco1
May 4, 2012 11:40 AM
Chrisinhouston
Dec 10, 2009 01:56 AM
vindicator
Nov 7, 2009 02:04 PM
