No start, no spark. New CPS. Need help!
Old Sep 7, 2019 | 11:00 PM
Matt Couleur's Avatar
Default No start, no spark. New CPS. Need help!
How do I figure out what's not working? I checked voltage to the coil and it's only 1.6 volt...
Old Sep 12, 2019 | 02:29 PM
greisinb's Avatar
How have you verified the "no spark" condition? Here is a wikihow article which tells you how to test for spark and to test the coil.
https://www.wikihow.com/Test-an-Ignition-Coil
Old Sep 13, 2019 | 02:47 AM
JUKE179r's Avatar
I bought a Lisle 19380 spark tester for cheap.
You place it on the spark plug wire while the engine is running and it lights up the bulb if you have spark.
Old Sep 22, 2019 | 03:51 PM
fishEH's Avatar
My 96 is doing something similar. It has been sitting a lot more since I have a different daily driver now.
The last two times I've started it, it has fired right up. But when giving throttle it bogs down, sputters, backfires. Rich smelling exhaust.
Both times I have let it idle for 15-20 minutes and come back and it was fine. I think mome has to do with water/dampness. When the engine sufficiently warms up the water evaporates and the problem goes away.
zuke
Sep 20, 2016 02:33 AM
Captian Adrianus
Sep 8, 2012 08:45 PM
scottshack
Apr 24, 2012 04:41 PM
possibly owner
Sep 7, 2009 08:33 PM
NWDisco
Dec 13, 2006 03:11 AM
