Noise on hard acceleration
Old Jan 5, 2022 | 12:54 AM
User's Avatar
Default Noise on hard acceleration
Hi folks.
I've recently taken an 03 D2 out of storage - it's sat for around 2 years while I'm dealing with other projects. Back when I built it, I only refreshed what really needed it. Fluids, tie rods, head gaskets, cooling system. Then I ran into an electrical problem that caused the seat not to move. Yep, that's all it took it to sit.
Anyway, COVID. More time..less real work. Fixed that with a new switch.
I took it to get the alignment done, and was doing some light Italian tune-ups (e volavo, volavo felice ) gioco di parole....
And well, it sounds like the front end is grinding itself apart. Is this going to be a wheel bearing, or diff issue? Sounds different from the previous wheel bearings I've run across.
Cheers!
Old Jan 5, 2022 | 01:30 AM
User's Avatar
And if anyone in the Chicagoland area can program a new key fob, that would be great! Currently do not have one, just an empty shell.
Cheers!
Old Jan 5, 2022 | 01:40 AM
The Deputy's Avatar
Can't hear anything in video. Front driveshaft may be froze up from sitting so long?
Old Feb 11, 2022 | 11:55 PM
User's Avatar
I don't think so, IIRC the front driveshaft is new from LK8.
I've pretty much summed it up to a wheel bearing. Has an ever so little amount of play that I had to concentrate on to notice.
Have new hubs coming in..
WoodlandsLandRover
Jun 24, 2021 11:29 AM
Alex_M
Dec 18, 2017 04:55 AM
nevillusa
Nov 19, 2014 03:59 PM
rancam
Dec 23, 2012 08:47 AM
'BamaBoy
Oct 17, 2010 07:08 AM
