Non genuine injector seals
His guys, I recently had a problem with my td5 where it had starting issues and cutting out.
I replaced the injector seals and problem was cured for a good 400 miles.
The car has now developed a terrible misfire, sounds like it's running on 4 and the AA man said injector no 2 readings weren't like the other 4.
Now I did use 10 quid ebay injector seals rather than genuine.
Is it worth trying again but using genuine seals? Can bad seals cause a misfire?
If someone checked out what the injectors are doing and found one that isn't behaving properly. That sounds more like a problem with the injector, wiring or FICM. I don't think the injector itself would act differently because of a bad seal. I'm in the USA so I don't have any experience with the td5. I do work on other diesels occasionally and it's not uncommon to see problems with injectors or FICM's. I think that's what I would look into first.
Loom was changed before the seals
austinlandroverbill
Jul 5, 2017 11:11 AM
Paul Grant
Oct 21, 2015 10:47 AM
Parts4x4Landrover
Member Group And Special Buys
Jan 22, 2008 05:47 AM
