Non sai ecu swap
Old Dec 14, 2019 | 05:44 PM
blakslee720's Avatar
Default Non sai ecu swap
So I’m in the middle of a head gasket and front cover job in my 04 disco and while scrubbing my engine clean, the thought of deleting the SAI occurred to me
after a bit of googling I discovered this has been performed successfully. My state, Connecticut, has emissions testing and an SES light will cause me to fail
So, I’ve found a non SAI ECU for prices that are worthwhile to me and I’m wondering what else I need to be concerned with doing the ecu swap.
i know I need to plug all the sai holes but that’s East. If I plug in a new ecu, will the mileage on the odometer change, anything else weird? I don’t have or know if the means to reprogram an ecu if need be
Old Dec 14, 2019 | 06:52 PM
mollusc's Avatar
The VIN of your vehicle includes coding that says it has an SAI system. Testing equipment will fail you if it doesn't find it.
Old Dec 14, 2019 | 06:57 PM
fudge
Old Dec 14, 2019 | 08:07 PM
Friday Night Disco's Avatar
You will have to get a new instrument cluster with the ECU otherwise the OD will flash at you
Old Dec 16, 2019 | 11:20 AM
Nosugar0carbs's Avatar
It’s not just a BCM/pcm/cluster swap, it is also a couple other emissions parts too. Tank pressure valve and the wiring that goes attatched.
Old Dec 16, 2019 | 12:05 PM
zuke's Avatar
Maybe somebody smarter than me can figure out if we can just put a fake load on the SAI plug and fool the computer into thinking that all is well.
Old Dec 17, 2019 | 05:37 AM
JUKE179r's Avatar
Yeah... like put a restrictor/pressure snubber in the air line system to keep constant pressure.
Old Dec 17, 2019 | 06:32 AM
mollusc's Avatar
Pressure won't help with the detection of the electronic components.
Why not just keep the system in place if it's operational?
GCBurke
Dec 18, 2018 08:00 AM
Llamasayswhat
Aug 12, 2018 09:36 AM
zuke
Apr 23, 2018 09:33 PM
Dan7
Nov 18, 2015 12:15 PM
floundering
Jul 7, 2015 04:53 PM
