Non start, battery fine. I think.
It's your battery. I just went through this on my P38. Sat for a while. Turned the ignition and got a rapid clicking sound.
Put some quality jumper cables on it and same thing.
Assumed it was the starter. I hit it with a hammer, nothing.
Resolved to change the starter, but was dreading it, so... I switched out with a battery from my disco and Voila!
That's the only thing that's got me stumped. Wih jumper cables from a running truck it wouldn't fire the starter. So I actually started to suspect my rather cheap jumper cables.
I have a mind to swap the battery anyway. Even though, now after starting with a booster pack it's running fine.
I also have to leave it sitting at times. Up to two weeks.
Not ideal.
Took the truck and a battery (AAP Silver Doohickey craft Blah....) I found in the back of the garage to AZ.
Battery on truck tested bad, back of garage one tested good, so it has a full charge and is on the truck.
Now, there is a reason it was stuffed at the back of the garage, and I can't remember what it is. But for now it's better than one that tests bad.
Seeing how I go.
Seeing how I go.
It's always been there. I hesitate to remove it, as I do see it as of benefit when I need. Unless of course it turns out to be the issue, then it's gone.
arrkerr
12-14-2005 10:06 AM
