None of the Power Works on Passenger Seat
Old Sep 28, 2017 | 08:14 PM
Armando's Avatar
Default None of the Power Works on Passenger Seat
Can't move it. Heat doesn't work. SRS code is getting tripped from the pretensioner on that side.
I just bought this car. Could there be some type of "main plug" going to that seat that is disconnected?
Everything under the seat seems to be connected
Old Sep 28, 2017 | 08:23 PM
Armando's Avatar
Just noticed that the backrest does work.it wont slide forward/back though
Old Sep 28, 2017 | 08:52 PM
Jeff Blake's Avatar
Check the fuses
Old Sep 28, 2017 | 09:01 PM
Armando's Avatar
Fuses under the seat are okay ��
Old Sep 28, 2017 | 09:12 PM
Jeff Blake's Avatar
Try applying direct 12v power to the motors
Old Sep 28, 2017 | 10:16 PM
Armando's Avatar
Where should I pull that from?
Also, it seems I may be borrowing trouble here. I have another passenger seat that I was going to cannibalize a bottom cushion from.
I'm going to plug the other seat in and see what happens (fingers crossed). I'll cannibalize the one I have installed now
Old Sep 28, 2017 | 10:19 PM
Jeff Blake's Avatar
the battery
Old Nov 4, 2017 | 07:33 PM
Redleg13fa's Avatar
my driver seat kept popping the 40amp fuse looked for the problem today and found it where I least expected it. Right being the seat controls pinched frayed wire between a metal bracket for the center console and the inner /outer console. No more popped fuse. I just cut it and used a butt connector. Then taped the hell out of it.
Old Nov 4, 2017 | 09:58 PM
Kdo58's Avatar
My passenger seat did not work, found a switch at a wrecking yard problem fixed.
1998DiscoverySE
Feb 8, 2012 02:41 PM
gboehm123
Mar 4, 2010 05:09 PM
lipadj46
Dec 4, 2009 02:13 AM
Granite Disco
Nov 7, 2008 02:00 AM
ROLLOVER
Aug 16, 2008 08:40 PM
