Is this normal?
Old Mar 2, 2020 | 05:36 PM
Brandon318's Avatar
Default Is this normal?
Both discos have collapsed coolant hoses when cold. Both are new LR OEM hoses.
Old Mar 2, 2020 | 06:06 PM
zuke's Avatar
No it's not.
Old Mar 2, 2020 | 06:12 PM
Jason Feuerstein's Avatar
You most likely have a bad radiator cap. Check the overflow tube for clogs as well.
Old Mar 3, 2020 | 12:07 AM
Brandon318's Avatar
Both the overflow tubes and radiator caps are new, from Lucky8. Any other brand I should try, assuming this one shipped broken?
Old Mar 3, 2020 | 06:25 AM
Try taking the radiator cap off and see if the hoses pop back. If it doesnt, there's a clog somewhere downstream. The prior owner of my Disco replaced the overflow tube with a generic rubber fuel hose; I would probably go this path again, since the plastic tubes have a tendency to crack.
Old Mar 3, 2020 | 09:20 AM
Brandon318's Avatar
They spring back, yeah.
Old Mar 3, 2020 | 04:08 PM
Then I would say they're your problem. I used a Gates piece when I replaced mine.
Old Mar 4, 2020 | 10:28 AM
Brandon318's Avatar
Lucky8 shipped a new one out to me yesterday. Will report back when I receive it.
whowa004
144
Sep 3, 2024 11:02 PM
The Deputy
16
Nov 4, 2022 07:11 PM
dmannrover
Jul 31, 2019 11:57 AM
The Deputy
Aug 25, 2018 05:45 AM
