Is it normal for the steering to groan when bleeding?
Old May 27, 2019 | 07:06 PM
Brandon318's Avatar
Default Is it normal for the steering to groan when bleeding?
Went through and flushed the power steering system, but while doing so the steering groaned a bit. Normal? Otherwise went well ¯\_(ツ)_/¯
Old May 27, 2019 | 09:52 PM
Bignacio's Avatar
Hmmmm, I just flushed mine also. Once in a while it would groan a lil bit. After I flushed the power steering system it hasnt groaned at all. The fluid was about 3 years old so I decided to change it while doing all the other fluids.I did it per the sticky write up...
Old May 27, 2019 | 09:56 PM
Brandon318's Avatar
Same, after finishing and taking on a test drive, no groan, dead silent. It was just during the procedure... which btw took shockingly less time than I thought it would. The pump bled through an entire liter of Pentosin before I had a chance to even react. Ended up burning through an entire can I probably didn't need to had I been prepped for that.
hemicharger69
Mar 4, 2019 06:38 PM
Manning
May 13, 2014 11:33 AM
novavon
Jun 28, 2010 12:31 PM
Long Haul
Jun 21, 2010 07:30 PM
range03
Apr 14, 2009 06:33 AM
