NOT a burned valve...an entireley different problem
Old Sep 29, 2017 | 12:56 PM
ElVerde's Avatar
Originally Posted by abran
also, a word on Time-Serts. They work. I have installed them on several motors without issue. I even pulled a motor from a parts car that had a bad time sert, it seemed that someone did not install it properly. There were 8 total but the one was bad. I sent it out and had a professional install a "Big-Sert" which is an oversized time sert and my sister is still running the motor after 10K miles.
How could you tell it was a "bad time sert"?
In any case, I appreciate all the feedback. We will obviously be using new bolts.
Old Sep 29, 2017 | 01:37 PM
abran's Avatar
It would not accept the torque when I tried installing the head. It spun during the last sequence.
Old Oct 1, 2017 | 02:57 PM
OffroadFrance's Avatar
TIP: Against all the pundits and what they say, always, but always use a smear of anti-seize, copper grease or oil on the threads of head bolts or studs to reduce high load friction. Only smear a small amount onto the threads but certainly not a huge dollop as that may cause an airlock when tightening.
ElVerde
Feb 21, 2021 03:20 AM
D95turbo
Feb 1, 2017 08:55 AM
wilson96rr
Audio/Visual Electronics
Feb 16, 2009 01:36 PM
Max_A6
Jun 28, 2007 03:55 PM
VB_Rover
Jul 20, 2005 02:43 AM
