Not enough heat in 2004 Disco
Old Apr 10, 2012 | 12:06 AM
hhalimi's Avatar
Default Not enough heat in 2004 Disco
Just drove from Detroit to Toronto, climate control was set to 70 with outside temp in mid 50's the vents were blowing relatively cold air. The air was getting warm if I cranked it up to 78. UltraGauge was showing engine temps to be 94 on the highway. In the city I usually run from 97-104 and did not notice the truck being cold Even in winter. Any idea why I don't have enough heat?
Old Apr 10, 2012 | 04:45 AM
Low coolant could cause that, along with clogged heater core. You could feel heater pipes in/out, if one is way colder, flow could be restricted. It is possible to flush the heater core in both directions. With 219F being reached, might be a good time to flush the main radiator as well....
philwarner
Nov 12, 2014 04:17 PM
jmason
Nov 17, 2013 06:39 AM
Savannah Buzz
Apr 15, 2012 02:17 PM
Joseph David
Mar 14, 2011 04:04 AM
Max_A6
May 30, 2007 02:42 PM
