Not getting any heat
Old Oct 30, 2008 | 01:41 AM
discoken's Avatar
Default Not getting any heat
Of course this happens right as the temperature here in Wisconson is starting to turn cold. Anyways today I was getting no heat coming out of the vents. It was just blowing out cool air. It did work normal one time but didn't again after dinner. Anyone have any idea on what to do? Its starting to get cold here!!! Thanks.
Old Oct 30, 2008 | 07:27 AM
Landzu's Avatar
Default RE: Not getting any heat
Anitfreeze maybe low ,,, most times that is all it is,,,or air locked.
Old Oct 30, 2008 | 10:05 AM
okdiscoguy's Avatar
X2 check you coolant level. See if it gets a little warmer as the RPM goes up & listen for sloshing.
Next may be a thermostat. Look at your temp gauge and make sure your motor is hot enough
Old Oct 30, 2008 | 01:02 PM
NiteTrain's Avatar
https://landroverforums.com/m_82593/tm.htm
jmason
Nov 17, 2013 06:39 AM
me 2
May 8, 2013 11:47 AM
umoms
Apr 3, 2008 06:22 PM
jskrebs
Aug 17, 2006 12:21 AM
