Not the u-joint
Old 11-29-2006, 06:38 PM
lowill's Avatar
Default Not the u-joint
Same old thing like every one else. 98 disco le (95650) thougt the joint was shot . You know the synthoms thunk noise when shifting into reverse, on acceration, and slowing down. Suspenion guy said it might be the trans. Will a trans flush help with this banging. Thanks
Old 11-29-2006, 07:04 PM
hoberock's Avatar
Default RE: Not the u-joint
Could also be the slop in the axle diffs. Have a rear end shop check it or you can put the tranny in park, jack up the rear end, and give your tire a spin by hand to see how much slop is in the system (make sure the drive shaft is not turning).
Also, if you have not had your tranny fluid replaced in a while, it would not hurt to replace the fluid and filter regardless.
Old 11-29-2006, 07:14 PM
lowill's Avatar
Will do.Ill bring the rig to the trans shop this weekend for a complete flush and tune up. Thanks
Old 11-30-2006, 11:29 AM
ORIGINAL: lowill
Hold the BOAT, how many miles on your truck, how often do you service your tranny?
You don't have a tranny shop do a tune up on a Rover, if you expext it to be done right. That is like going to Midas for a brake job, you get a big bill and truely junk for parts.
e-mail me with your tele number and I'll call you.
Mike
D2 2003
05-22-2007 12:32 AM
pom1987
04-20-2006 04:37 AM
RobFrey1
09-22-2005 02:12 AM
jasonsLR
08-11-2005 01:21 AM
Bene
05-23-2005 01:00 PM
Quick Reply: Not the u-joint
