A note on changing the auto transmission fluid/filter
Old Jan 12, 2012 | 06:19 PM
wrp's Avatar
wrp
Default A note on changing the auto transmission fluid/filter
(This is an FYI - there are no questions here) I broke off two corner bolts of the total of six bolts that hold the automatic transmission pan in place. I then broke one Easy-out, and it looked like no hope for drilling it out.
So instead, I purchased from the dealer for $7 each two center spacers that help hold up the pan on the sides, part RTC5734. Then I drilled and tapped two new holes adjacent to the corner bolt holes, and now the everything is good. The case is very soft aluminum, but the torque on the bolts is 6 - 12 ft-lbs. (This is a '99 D-II, with about 126k miles, and yes the trans. fluid was changed 2-3 times before)
Old Jan 12, 2012 | 08:25 PM
Sorry for your problem, hurray for the fix, and thanks for posting the solution! Post a pix of your handiwork?
Old Jan 12, 2012 | 10:46 PM
elrocha69's Avatar
If you want to save money, any older BMW with an automatic also uses the sam ZF 4hp22 as out rovers and have the same spacers, so you could go to a salvage yard and get them cheaper if it is worth the savings. I am not sure what the dealer charges.
Old Jan 13, 2012 | 08:58 AM
kenk's Avatar
That is a good idea. I will have to remember that as I will be doing my filter and fluid soon.
kpl1228
Mar 19, 2012 09:02 PM
Dezert Rover
ROAMING WITH FRIENDS
17
Jan 1, 2011 06:34 PM
Spencerfitch
Oct 7, 2010 12:43 PM
03discoman
Apr 22, 2010 10:07 PM
caleb
Nov 30, 2009 09:10 AM
