O2 Connectors
Old Jun 19, 2014 | 12:38 PM
Charlie_V's Avatar
Originally Posted by acamato
You can use a Posi-Lock posi-tite splice. Posi-Tite- Watertite Connector
Bosch uses a special posi-lock splice their universal 02 sensor.
Bosch Premium with OE SmartLink
4 posi-tite connectors are $9 shipped Order Online- Discounts
That sounds better than my twist and tape method for sure!
Old Jun 19, 2014 | 02:38 PM
RoverMasterTech's Avatar
Just crimp connect them together. Use the heat shrink glue inside ones. Forget the plugs.
Old Jul 2, 2014 | 05:01 PM
emt2976's Avatar
Which color coded wires do what function? I have scoured the electric diagrams, but I am not an engineer. This is what I have for the left front:
purple/brown-fuse 2
orange/white-ecm
orange-ecm
black/red-ecm
how do I tell which one is heater, ground, etc?
Old Jul 2, 2014 | 09:24 PM
Jared9220's Avatar
purple/brown-fuse 2
orange/white-ecm
orange-ecm
black/red-ecm
(All pins I refer to are on connector C0635 of the ECM)
*Purple/brown= Heater Supply fuse 2 >>>> goes to O2 white wire
*red/black= earth/ground ecm pin09 >>>> goes to O2 grey wire
*orange= input/signal ecm pin15 >>>> goes to O2 black wire
*orange/white= Heater Drive ecm pin19 >>>> goes to O2 White wire
Old Jul 3, 2014 | 08:34 AM
Jared9220's Avatar
This is where I got the information I posted above^^^^^
I used this color diagram and found which color wire went to which pin on the ECM connector 2 (0635).
O2 color wire guide.pdf
Then I looked at this page in the RAVE and found what pin does what function. (example. pin9 is for ground signal.)
O2 pin information.pdf
Give a man a fish, feed him for a day
Teach a man to fish, feed him for life
jafir
Apr 10, 2010 09:12 PM
Disco Fuego
May 6, 2009 08:37 AM
zoomlenz4u
Jan 15, 2009 01:35 AM
MrSabie
Aug 29, 2006 02:06 AM
sclarkie
Aug 11, 2005 02:20 PM
