O2 Sensor Blow Out
Old Mar 12, 2012 | 12:18 AM
earlyvws's Avatar
Default O2 Sensor Blow Out
I have replaced all 4 o2 sensors with bosch from local Autozone. I have had to replace the (bank 1 sensor 1) 3 more times (so a total of 4 new o2 sensors). I forgot the exact code right now but the description was bank 1 sensor 1 running lean.
I have also replaced the mass air sensor with a rebuilt one from oriely, but I will be ordering the on roverparts. After changing the mass air I started getting tranny codes, for 4th gear incorrect ratio. Never had that problem until the new mass.
Any ideas what is messing up the bank 1 sensor 1. I also cleaned the connection with electrical cleaner and dryer.
Old Mar 12, 2012 | 04:29 AM
MAF is perhaps the issue on the tranny codes. The engine computer sends a steam of data to the tranny, and the tranny computes what gear would be best. When input data pushes that out of a range of possibilities, the wierd ratio codes can result. Here's a page that shows you all the talk going on betwen the two computers.
File Type: pdf
Paul Grant
Oct 19, 2010 07:10 PM
willlane
May 11, 2010 05:09 PM
Eak69
Apr 4, 2010 11:52 AM
ogden45
Dec 29, 2008 08:29 AM
PITTDISCO
May 31, 2008 12:26 PM
