O2 Sensor Repair
Old Oct 5, 2023 | 12:08 PM
redrover75's Avatar
Default O2 Sensor Repair
I have researched all sorts of methods to remove an O2 sensor. Upon closer review it looks like it is solidly rusted together. I broke a couple extensions trying to pull it off, The 02 wrench splays apart.
Is it worth fighting it to get it out? Or, should I just cut the section of the pipe, and clamp in the below with two exhaust clamps? This would certainly be faster and probably less painful.
https://www.ebay.com/itm/284620814023
Any other ideas I should consider?
Thanks
Old Oct 5, 2023 | 12:19 PM
XRAD's Avatar
I used a cast heavy duty O2 sensor remover and penetrating oil and heat, but I did have the Y pipe off the car which really helped. also, you can just buy the bung and weld it in if old bung gets ruined....
Old Oct 5, 2023 | 05:38 PM
Extinct's Avatar
You can cut the wire off and use a deep well impact socket. I have also seen people put a hose clamp over the 02 sensor socket to keep it from splaying open. Soak it in aerokrol for 3 or 4 days, spray it every day. The aerokroil will usually loosen it. And yes, worst come to worst, take it to muffler shop and they will cut the bung out and weld a new one in.
Old Oct 5, 2023 | 06:04 PM
Killerkaw's Avatar
Kroil is awesome, let it work
Old Oct 6, 2023 | 12:03 PM
miron's Avatar
largest crescent wrench i had did the job on my O2s
Old Oct 7, 2023 | 10:10 AM
redrover75's Avatar
I damaged the wire, so there is no signal, which is giving me a light. So, now I am committed. The wire was bad for a long time, I just finished it off. Going to try soaking for several more days, then a 22mm box wrench. It almost looks like it is rusted into one piece. maybe a cut off wheel where the bung and o2 sensor touch?
Old Oct 8, 2023 | 04:59 AM
Extinct's Avatar
Yeah, if you are that committed you could cut the top of the sensor off and then use an impact socket on a long breaker bar. Keep soaking in the aerokroil.
DiscoRover007
Jun 28, 2011 06:26 PM
pilsner
Oct 13, 2010 11:10 PM
discolvr
May 12, 2009 07:09 PM
Roveroh
Jun 27, 2008 11:39 AM
EATMAN
Nov 10, 2006 12:15 AM
