Obd port problem
Old Jan 27, 2016 | 08:11 PM
sickws6's Avatar
Default Obd port problem
So never had problems connecting my scanner now it won't connect. I wiggle it a little to briefly get power to scanner but then it still won't connect. Any suggestions?
Old Jan 27, 2016 | 08:34 PM
dgi 07's Avatar
Check the pins. Probably spread to far.
Old Jan 27, 2016 | 09:24 PM
Alex_M's Avatar
Yep. If that doesn't clear it up then try spraying some electrical parts cleaner. Might be some corrosion that needs cleaning out.
Old Jan 28, 2016 | 08:32 AM
sickws6's Avatar
What do I need to do if the pins are spread out? Just straighten them or something.
Old Jan 28, 2016 | 09:35 AM
dgi 07's Avatar
Opposite actually. The pins on the OBD2 port are female. They need to be pushed back together. A long thin pick may work, or a pin terminal tool may work better.
jw928
Dec 31, 2020 12:23 PM
jtherien53
Dec 18, 2008 01:22 PM
Mark G
Sep 26, 2007 06:49 PM
dc10freighter
Jun 21, 2007 09:39 AM
dofbft
Oct 20, 2006 02:09 PM
