OBD2 port doesn't work
I have a 02 Disco, with 150k on the clock. I have a check engine light with no driveability
issues. I cant get the diagnostic port to work. I tried the fuses #20 under the steering wheel. I don't think I am getting power to the connector port. It appears that this problem
has come up before on this forum. Has anyone out there resolved it?
Thank You
Thank You
Well I have a similar problem, as mine if I get in the truck with the ultra guage plugged in, it might work. If it doesn't I have to unplug the UG and try replugging it in several times and hoping it comes on and then have to wait for it to connect back to the truck. As you stated I checked the fuses and all good. So maybe we're in the same boat
So that being the case, I could run a new wire to a better ground and voila problem solved. Never thought to check the ground. Thanks
grandkodiak
03-06-2013 05:35 PM
