OBDII Scanner
Old Jun 10, 2010 | 07:38 AM
Are you referring to is it a OBD1 or OBD2, if so, it is an OBD2.
Old Jun 10, 2010 | 10:23 AM
Soccer Dad's Avatar
Default OBDII Protocol
The protocol is the Data Format the ECU of the car uses. The scanner first tries to find the correct Data Format (the protocol) when just plugged in. After the correct protocol is established, the data can be collected.
My scanner (OBD 2)cycles thru the protocols and can't "shake hands" with the car, so no data can be read.
I'm just wondering if the scanner has the correct protocol for the '99 Discovery 1.
SD
Old Jun 10, 2010 | 04:50 PM
You are trying this with the key ON right? The key MUST be in the "RUN" position, if not it will not connect with the ECU.
Old Jun 10, 2010 | 09:57 PM
Soccer Dad's Avatar
LOL!!! Yes, with the key on and in "run" as the instruction sheet says.
I think I'll go to the neibour tomorrow and try it on his Found On Road Dead to verify the scanner.
SD
adwarren78
Aug 28, 2010 11:55 AM
leadfoot
Sep 14, 2009 05:00 PM
raptorial
Feb 2, 2009 09:09 PM
Rich 00 DISCO
Dec 29, 2008 03:25 PM
Elhoff
Oct 31, 2006 10:38 AM
