Occasional oil leak
Old Jun 21, 2016 | 08:16 PM
  #21
adolfojbonilla's Avatar
Originally Posted by Motorhead1
If you search this forum for "Front crank seal replacement" or "Oil leak front seal" etc, you should find and read a lot of posts with info on fixing. You can also read the manual. You need the right tools to remove the harmonic balancer, fan. Pry the old seal out, grease the new rubber seal lip surface lightly, very carefully tap the new one in without damaging it.
...Thanks Motorhead1, I do have the tool to remove the fan, but I was thinking I needed another one to access the seal. I'll check the forum and see what surfaces, thanks! ;-]#
Old Jun 22, 2016 | 08:41 AM
  #22
Motorhead1's Avatar
I use a strap wrench similar to this to hold the harmonic balancer in order to loosen the bolt.
https://www.amazon.com/BOA-BO13010-C...s=strap+wrench
jamestfl
May 28, 2014 09:52 AM
Street Wolf
Sep 6, 2011 04:15 AM
jkeving
Jun 9, 2011 06:58 PM
sidinseattle
Jul 16, 2010 10:21 PM
krazzz
Sep 28, 2009 09:38 AM
