Odd coolant leak - Help 02 Disco SE
Old Nov 11, 2011 | 04:26 PM
rickm's Avatar
Default Odd coolant leak - Help 02 Disco SE
I have little knowledge with vehicles. I've attached two pictures of a coolant leak I have. You can see the coolant spraying out just above the hose. It's almost like it is coming out of the metal housing above it.
Is this an easy leak for me to repair????
Attached Thumbnails Odd coolant leak - Help 02 Disco SE-resized-leak-pic.jpg   Odd coolant leak - Help 02 Disco SE-resized-pic-leak.jpg
Old Nov 11, 2011 | 04:31 PM
01d2Jeff's Avatar
Try replacing those two clamps with the screw-type clamps - see if that helps?
Old Nov 11, 2011 | 04:43 PM
lordmorpheus's Avatar
Land Rover Fuel System Parts | Throttle Body - Heater Plate Kit
This is a very common failure. It is a DIY repair and fairly simple. If you haven't already, replace the Dexcool antifreeze with a universal formula after the repair.
Old Nov 11, 2011 | 05:41 PM
boris_gti's Avatar
Yup,
Standard maintenance item. Nothing to be concerned about. Buy the kit and replace it.
Old Nov 12, 2011 | 09:23 AM
It is common, not hard to replace with a new kit from the dealer. Make sure you do it quickly before your coolant gets to low and you over heat your engine.
Old Nov 13, 2011 | 01:27 AM
rickm's Avatar
Thanks everyone. Ordering the part on Monday. How long will it take me to replace / remove the other one etc? What tools will I need? Will removing the old one make me lose all my coolant and I'll need to refill?
Sorry for the basic questions.
Old Nov 13, 2011 | 07:49 PM
Bes ure you keep topping up radiator coolant jug until parts arrive, or don't drive truck.
If you have not replaced coolant in last six months: drain, flush, repair, refill. Use a green or yellow coolant. DO NOT USE DEXCOOL.
Old Nov 14, 2011 | 08:59 AM
Depends on you and your mechanical skill, cane take from 45 minutes till you get it done, but it is not a hard job. Be careful when removing the large plastic air intake hose, they get brittle and can break. Make sure to clean out the t/body with carb spray for a better idle.
ZMonet
Jun 24, 2016 04:00 PM
archaeology_student
May 4, 2013 05:31 AM
CUpgt
Apr 26, 2013 07:17 PM
llPANCHOll
Jan 18, 2009 08:31 AM
BKkentgreen
Oct 8, 2005 01:31 PM
