Odd shifting and hesitation?
Old Nov 14, 2012 | 08:26 PM
lr2001silver's Avatar
Banned
Very likely. I remember when you joined and you had stated you got this from your Dad! They should give you the records.
you can crawl under it and take out the plug and check fluid level. To check filter you have to take if pan.
Old Nov 14, 2012 | 08:36 PM
ashtray's Avatar
I'll check the fluid when I get free time from school. Looks like Friday is off to the dealer time. I'll let everyone know what the situation turns out to be.
Old Nov 15, 2012 | 09:26 AM
SSL9000J's Avatar
It could be as simple as low transmission fluid. You might want to investigate a little bit yourself before taking it to the stealer$ship.
Old Jul 10, 2020 | 04:38 PM
arains44's Avatar
Sorry to revive an old thread, but my truck has a very similar problem. Recent Trans fluid change and MAF change.
Did you get this resolved @ashtray ?
Old May 27, 2023 | 12:09 PM
Lady-driven's Avatar
Default Solution: throttle bottle cleaning
In my experience, the reason your transmission is hesitating to shift is because it’s not getting enough air in the intake probably because the throttlebody swinging door is trapped in the closet position so if you clean out your throttle body with carburetor cleaner, you don’t even have to take it out with, and that should help smooth out your shifting. There’s videos on YouTube for cleaning an LR three throttlebody.
weepit
Mar 6, 2013 08:56 PM
JerrodSteph
Sep 21, 2008 11:52 AM
brokedowndisco
Apr 12, 2008 02:36 PM
zr440snoproman
Jan 18, 2008 08:21 PM
rvrchk320
Nov 30, 2007 07:53 AM
