Off Road Light Wiring
Old Oct 23, 2020 | 09:56 AM
redrover75's Avatar
Default Wiring
Where I had it connected, the two larger bolts, does not work. I discovered that is the starter incase anyone is curious. Any suggestions on where to tap into? Could I just run the red wire to one of the fuses? I am sure that is a bad idea for some reason. Or, just remove the terminals and go to the battery directly? There is a relay, attached to the firewall. In this location, I can stash all the wiring in the jack storage space.
The switch wiring kit I bought is
Amazon Amazon
The wires attached to switch to the relay are way too short, will need to splice in more but that is easy enough.
Old Oct 23, 2020 | 10:00 AM
whowa004's Avatar
I have successfully tapped in on the starter wires as well as straight from the battery, depends on if you want the accessories to be usable when the key is in the on position or not.
Old Oct 23, 2020 | 10:10 AM
Richard Gallant's Avatar
I usually run direct to the battery it is just cleaner.
Old Oct 23, 2020 | 12:15 PM
redrover75's Avatar
Great, that is easier anyway.
Someone here installed the switch in the same place as below. Looks pretty good, just hogged out the hole to match the switch, when I get an OEM switch I can just put the face plate back on.
Now, I just need to wait until Monday for the other parts to arrive from Luycky8, should be Monday, if I get lucky, maybe tomorrow.
I found these two wiring harnesses under the dash, does anyone know what they are for?
Old Oct 23, 2020 | 12:16 PM
whowa004's Avatar
Agreed. I'm waiting on a dual battery tray and will be redoing all of my accessories straight from the second battery. This has been in the works for a while and knew anything I added was going to be redone so the starter was used for the switchpro knock off as it didn't require any rewiring to fit the stud on my battery terminal that my winch is hooked to.
Old Oct 23, 2020 | 08:25 PM
baileyrockhound's Avatar
My forward facing driving lights, currently hella 500s are running off a foot swtich,
fabbed a bracket from 1/4 inch abs its attached to the foot rest
made a similar mod to my last rig, easily one of my favorite mods, runs to a relay
windsoreight
Jun 14, 2014 09:03 AM
jalodge
Sep 30, 2013 05:02 PM
eitydeuce
Sep 17, 2013 08:09 PM
vandyboy
Sep 13, 2012 01:54 PM
mpparamedic
Jul 24, 2010 06:55 PM
