The Official Extinct Inline Thermostat Mod Thread
Old 07-12-2022, 04:53 PM
JUKE179r's Avatar
After 5 months of owning the kit, I owe @Extinct a review once I install it here in England.
  #302
Old 07-12-2022, 04:56 PM
JUKE179r's Avatar
Originally Posted by Sandman614
Just got done with my install, topped off while running, revved to 2k rpm, went for a test drive and she stayed at 199 for most of the drive but crept up to 208 after going up a Long Hill. Parked it at home and left the hood open to cool off walked back by and saw this.
is this a Range Rover setup?
  #303
Old 07-12-2022, 05:39 PM
Did you notice any coolant loss?
  #304
Old 07-12-2022, 06:19 PM
Sandman614's Avatar
Range Rover? Because the electric fans, nah I am testing out a Ford Fusion dual e-fan setup.
A slight leak but no drip from the inline housing(sensor fitting I think). The overflow tank is just over cold full.
I would have thought the pressure would equalize by now, still flat.
  #305
Old 07-12-2022, 06:27 PM
Richard Gallant's Avatar
Received 1,178 Likes on 815 Posts
@Sandman614 is the return hose from the rad to expansion tank hooked up and clear. And does the hose return to round if you remove the cap
  #306
Old 07-12-2022, 06:31 PM
Sandman614's Avatar
I saw coolant returning to the tank when I was filling. Yea, just took the cap off and it sucked air in.
  #307
Old 07-12-2022, 06:44 PM
Try running it up to temp with cap off, and tank raised but watch the temps, over 200 you should shutdown
  #308
Old 07-12-2022, 06:49 PM
Sandman614's Avatar
She's nose down my driveway, I'm gonna turn it around and run it up to temp and see if it'll take anymore coolant after dinner.
  #309
Old 07-13-2022, 02:32 PM
Sandman614's Avatar
I think I got some air out, at least I saw air bubbles in the tank. Went for a ride and it didn't get as hot granted it's 10-15F cooler ambient today. It's still cooling off after my ride but it's been parked for at least 2 hours and it's not as flat as it was the last time.
  #310
Old 07-13-2022, 02:38 PM
At this point take the simplest route pull the thermostat, rebleed leave it out and go for drive. You could have a problem with the thermostat, rad cap or the bleed hole in the thermostat could be blocked. The hose collapses because of a vacuum created when the engine cools if it still does it with the thermostat out.
Try running with the cap 1/4 to half turn loose, leave the thermostat out, if you still get a flat hose it could just be the hose or something else preventing normal coolant flow.
Quick Reply: The Official Extinct Inline Thermostat Mod Thread
