The Official Extinct Inline Thermostat Mod Thread
#361
#364
- Extinct's inline thermostat
- 2991 Hayden sever duty clutch installed this summer
- Dorman fan blade
- New Nissens installed in spring
- Coolant level looks great
- SAI
We had a cold winter spell this week. Running the truck all day. Ambient around 40 to 46-deg F today. Coolant temp typically in the 168 to 174-deg F range. I just started getting the P0126 code today. The Ultragauge has also showed a slight drop in gas mileage.
The Hayden 2991 Severe Duty is great for the summer to keep temps down, especially when under load or offroading. I am thinking perhaps of switching back to the 2781 Standard Duty for the winter. Anyone tried this and can share your experiences... or anything else to fix the P0126?
Thanks!
- Dorman fan blade
- SAI
Thanks!
#365
#366
I did not realize a radiator muff is an option. I just did some research and see that they are available from the UK. Thanks for the suggestion.
#367
Installed the inline kit this afternoon. The disassembly of the OEM cooling system was the hardest part. Gashed my hands a couple of times while breaking the hoses loose from the adapters.
Looking forward to see where my temps end up. So far it's been running in the 206 to 210 range with temps in the 30's and 40's.
Looks like I have a drip between the t-stat housing. Thought it was the nipple so added more pipe tape and retighten. Would the thermostat not being aligned properly cause a leak? Using the reusable gasket.
#368
Yes, same thing happened to me. Gotta have the t-stat perfectly centered on the gasket.
Erikleonard (01-08-2023)
