Oil cooler hoses still available?
Old Apr 29, 2020 | 07:47 PM
DiscoJax's Avatar
Default Oil cooler hoses still available?
I have an oil cooler hose leaking at the quick disconnect. It has about 360000 miles on it so I'm looking to replace it. But I can't find any place that still stocks them. Strangely the transmission hoses are still available. Can someone suggest where I should look?
Old Apr 30, 2020 | 01:35 PM
Brandon318's Avatar
Check Britpart and eBay.
Old Apr 30, 2020 | 01:44 PM
Tony Luna's Avatar
360K!!!
I've had success by replacing the O ring in the quick disconnect.
Old May 1, 2020 | 10:06 AM
DiscoJax's Avatar
In case someone else is looking for those hoses the part numbers are PBP101100 for the driver's side and ESR4626 for the passenger side.
Old May 10, 2020 | 06:43 PM
DiscoJax's Avatar
I wasn't able to find any replacements for sale so I decided to see if I could replace the O-rings. Turns out there are 2 O-rings in the quick disconnect with a thin plastic washer in between. The high temp O-rings I picked up at the auto parts store were not the exact size. (Tan ones in the picture) If I put 2 new rings in I was not able to get the connector on the cooler. Using an old ring and a new ring seems to work.
Old and new O-rings
Where the O-rings sit in the quick disconnect
Old May 10, 2020 | 08:00 PM
Discorama's Avatar
As a replacement 14 mm compression fittings work.
Old May 10, 2020 | 09:06 PM
ZGPhoto's Avatar
360k? Put her out of her misery
metzdmichael
Jul 12, 2018 04:04 PM
Beaulim
May 2, 2014 08:03 PM
stamper620
Apr 8, 2013 11:59 AM
atancreti
Jul 13, 2011 10:20 PM
irishrover
Mar 25, 2007 12:34 PM
