oil cooler leaking, rear break pad replacement
Old 08-26-2006 | 07:29 PM
echoes_and_fractals's Avatar
Default oil cooler leaking, rear break pad replacement
as said in the title, the oil coolant line leaks, not sure if its the send or return. is there anything spacific i need to do or can i just replace the line?
also, she needs new rear break pads. i've done chrysler and GM pads, but land rovers are wierd so i wanted to know if there is anything special that i need to do, or is it just a straight frwd pad swap? any special tools i should get for either of these jobs? sorry if i sound stupid but i am new to land rovers and help will be appreciated. tanx
JOE
Old 08-27-2006 | 12:11 PM
Default RE: oil cooler leaking, rear break pad replacement
Joe,
For the engine oil cooling lines, replace them both, they are a hugh fire hazard. You can buy new factory lines on line from places like Atlantic British, Rover Connection or DAP or sometime from lock shops that will make them to fit , usuallt being a better hose and less expensive.
As for the brake pads, not a big deal on your truck, how are the rotors,if they need replacing. there is a little more work, but still easy enough. Make sure yo change out your brake fluid also. The pads are best bought at one of the above mentioned web sites also.
Mike
Beaulim
05-02-2014 09:03 PM
DavidG
01-03-2014 09:26 AM
javven
07-15-2012 11:09 AM
ALEXAN
10-24-2009 01:21 PM
brooksa
03-02-2009 06:20 PM
