Oil Filter same as Ford FL1A?
Old Oct 7, 2007 | 03:05 PM
Mark G's Avatar
Default Oil Filter same as Ford FL1A?
Is the 4.0L (Disco 1) oil filter mount the same as a Ford FL1A? That's a really universal mount. My Toyota truck, JD lawn tractor, Jeep all use that mount. Other vehicles I've had in the past have used same mount/threads too - even Fords!I forgot to check until after I had the new filter on. If so, it opens up other possibilities. Thanks
Mark G
Old Oct 7, 2007 | 05:35 PM
llesra's Avatar
Default RE: Oil Filter same as Ford FL1A?
yes
Old Oct 8, 2007 | 06:51 AM
Landzu's Avatar
I would check that I know the Mobil One oil filter I use will fit
a Jeep/Dodge trucks but not Fords.
Old Oct 9, 2007 | 01:28 AM
geotrash's Avatar
The filter mount is indeed identical to the FL-1A. The K&N 3001 is a direct replacement for the FL-1A and the 3001 is the one recommended by many Rover folks as a better filter than the original. It is larger in capacity than the one specified for the Rover, but the seal, threads and ports are the same.
Dave
Old Oct 9, 2007 | 03:22 AM
llesra's Avatar
heres a good article about oil filters. all the filters in the test work for the rover engine.
http://minimopar.knizefamily.net/oilfilterstudy.html
Old Oct 9, 2007 | 08:18 AM
After you look around, still try and stay with either the Mobil 1 or the K&N 3001, between the filter media and the internal valves, these seem to be some of the best as far as the rovers go, mainly no dry starts after sitting awhile.
earlyrover
Jan 15, 2017 12:45 PM
mike552
Apr 25, 2010 12:57 PM
Benhamtroll
Off Topic
Jul 22, 2005 01:40 PM
traffictech870
Off Topic
Mar 31, 2005 01:49 PM
BigMike
Mar 20, 2005 10:51 PM
