Oil Filter Sandwich Adapter
Old May 23, 2010 | 12:32 PM
aemnky606's Avatar
Default Oil Filter Sandwich Adapter
I'm looking for that same plate for my 96 disco I. will the same one that fits the DII fit my Disco I?
http://www.glowshiftdirect.com/oilfi...-34unf-16.aspx
Thanks
Walter
Old May 23, 2010 | 05:53 PM
greg409's Avatar
Thanks
Walter
That's the one I bought last year, works fine.
luck,greg
Old May 23, 2010 | 05:58 PM
aemnky606's Avatar
Thanks Greg i'm goint to get in the morning then.
Walter
Old May 23, 2010 | 06:06 PM
greg409's Avatar
Walter
When I installed mine, I used the extra port to plug in my good mechanical testing ga.
I found my actron electric to be off by 5#'s low.
I calibrated it, you might want to check your ga. against a known good mechanical.
I can also use my 100# testor on the fuel rail for pump/regulator press.
luck,greg
caymandrew
Feb 4, 2020 08:03 AM
Chris-bob
Mar 15, 2012 07:02 AM
bcameron70
Aug 23, 2011 09:14 PM
meltdowndave
Feb 1, 2010 04:20 PM
