Oil Help!
Old Sep 1, 2012 | 11:22 PM
jack94's Avatar
8th Gear
Unhappy Oil Help!
Hello I Just Replaced my oil at 5000km and I noticed the there was a large amount of oil under the Front right tire, on a plastic cover (From drivers perspective).
I'm not sure where the oil is from but here seems to be the source, and I'm not really sure what I am looking at.
My dad (I am 17, P plater) thinks it might have something to do with the Steering assist, which we then looked at the lid for the tank and noticed where there wasn't any seal.
So does anyone have any idea what and where this oil is coming from?
Also does anyone know if there is meant to be a seal on the lid?
And lastly this is a slightly different topic but does anyone have any suggestions where to get a new oil sump drain nut... (It was put in too tight by the previous mechanic)?
And lastly any suggestions for a replacement here?
Thanks
Old Sep 1, 2012 | 11:23 PM
jack94's Avatar
8th Gear
Sorry second photo was ment to be
Old Sep 2, 2012 | 08:48 AM
oilspotLR's Avatar
I say go to the car wash and gently wash/degrease that area. Then see where the oil comes back from.
Old Sep 2, 2012 | 09:02 AM
D2's take power washing very well as long as you do not have the factory grey plug wires. If you have them, you now have 2 reasons to up-grade to a new set of 8 mm silicone wires like STI's or Magenacor's.
Then power washing your entire engie, bottom first and you will get a better idea what is leaking.
Old Sep 2, 2012 | 09:55 AM
You can get a new drain plug at any autoparts store, take your old on in and match it up with a new one.
Old Sep 5, 2012 | 09:25 PM
jack94's Avatar
8th Gear
ok, thanks i will have to look into the plugs.
Speed racer
Oct 11, 2008 10:56 PM
jkeving
Jan 19, 2008 08:06 PM
shagybruce
Feb 8, 2007 02:52 PM
